system
October 14, 2009, 12:44am
1
Hey Guy,
What is teh best approach here, i am looking at creating a cell in a webi report that will write a warning message on the report if the row returns is larger than 100 000 …
how can i do that?
Cheers
C
Intelligentsia (BOB member since 2005-06-07)
system
October 14, 2009, 1:04am
2
hi there!
try this:
=If NumberOfRows([Query 1]) >= 1000 Then “Warning Message”
Query 1 is your data provider name.
regards,
r.A.
R.A. (BOB member since 2008-10-28)
system
October 14, 2009, 3:09am
3
Yep working fine : .
=If(NumberOfRows(DataProvider([Object name]))>100000;"Warning - This report may content partial Results ")
[Moderator Edit: Added code formatting - Jansi]
system
October 14, 2009, 11:22am
4
I don’t how they do things “down under,” but here in the States we would usually say “may contain partial results.”
Just a friendly tip!
system
October 16, 2009, 5:43am
5
I know it was a typo picked up on testiong, but cheers for the reminder
