Hi, can someone help me with code for a loop? I’m trying to write a loop that will look at a string that I have in the Keywords of a report and set a variable to the result.
Example:
Say my string is: “9,4,10” in Keywords. I want to loop thru this string and set a variable to the numbers it gets. (the comma is the seperator) So, the first loop will return 9, the 2nd loop will return 4, the 3rd loop will return 10. I want to use this to set some parameters. I’ll convert it to a number after I retrieve it. I’ve been trying InStr with a comma as my value but not having much luck…
A basic example:
Dim myReport As Document
Dim strKeywordCopies As String
Dim strCopy as String
Set myReport = ThisDocument
strKeywordCopies = myReport.Keywords
What I want to happen…
Start loop
strCopy = 9
repeat loop
strCopy = 4
repeat loop
strCopy = 10
Any help is appreciated…
thanks!
nonyup (BOB member since 2008-01-07)
