I run BO 5 and Webi 2.5 with IE 5.0 with no problems. During the beta of these releases there was a line you had to add into one of the Webi Server configuration files but even then it worked. Thank you,
Jackie Dunn
BellSouth Affiliate Services
(770) 803-2239
Same with me - I have been running these versions exclusively with IE 5.0 and have no problems. There was a time during the Beta of these that you had to manually add a line to one of the Webi Server config files to be able to use IE 5.0 - maybe that’s what he’s confused about… Thank you,
Jackie Dunn
(770) 803-2239
Steve - I don’t know the answer, but I do want to assure you that Webi 2.5 does work with IE 5.0. I have been using it with no problems. There was a time during the beta testing of this release that you had to manually add a line to one of the Webi Server configuration files to be able to use IE 5.0 but I never received that error - have you tried it on more than one machine with IE 5.0? Have you ruled out a workstation setup issue as the cause? Thank you,
Jackie Dunn
(770) 803-2239
