Does anyone know if it is possible to see all the previous posts and replies I have contributed to this forum? Sometimes I need to retrieve an older post, but have forgotten where it is.
gjwl_8 (BOB member since 2010-02-17)
Moderator Note: I moved this to ‘About BOB’ section.
Hi Gary, when you click on Forum Index, check the top right corner to search. You’ll find ‘My posts’ as one of the options. This is what you’re after.
Jansi (BOB member since 2008-05-12)
Also, when you see a list of posts, there will be a red triangle to the left of any topic that you have participated in.
MichaelWelter (BOB member since 2002-08-08)
But that color is something that you set in your profile. But I’m not sure if the Red color is by default.
Thanks a lot guys! That’s really helpful!
