We have IS 4.2 SP1 installed in BO 4.1 SP2. Problem is when I do the ‘View Data’ in Data Insight, I get the below error
‘The Service Data Services View data services is unavailable, check If the server EIMadaptiveprocessing server is running and enabled(COR -10250)’
I’m able to create the connection successfully and also could add tables from metadata list. When I go to servers in CMC it shows, all the servers are enabled and running successfully.
Note: Initially the view data didn’t work only for VIEWS, now it stopped working for everything including data base tables, flat files etc.
Any help would be highly appreciated
Thx
Sarav
Sarav Dev (BOB member since 2009-02-26)
