Hi All
I want to write a macro, which should be executed when a document is closed. This macro should be active for all the documents. Any idea…
This was possible in BO4. We used to create a script called BusObj.spt with event handler for document close.
Thanks in advance
Vasan
Baton Rouge International Inc
Data warehousing Division
