Hello!!!
I’m having problems with my VBA code in Xcelsius.
The thing is, I want to transfer some data from a Excel spreadsheet to the Xcelsius spreadsheet.
For this, I created a button in Xcelsius spreadsheet that activates a VBA code.
This code gets a file choosed by the user, open it, copy the data to Xcelsius and then close the file.
The problem is, when I run my code from whe VBA editor, it works fine.
But when I run it from the button, by clicking the button, it gives me an error 1004, that the Open function from Workbooks could not be processed.
This problem happens with other funcions that uses Excel.Application, like Application.DisplayAlerts, or things like this.
But only in the click of the button. Runing from code behing works fine.
My code, in the button is:
Private Sub CommandButton1_Click()
'Declare all of the variables needed
Dim file_name
Dim avarSplit As Variant
Dim intIndex As Integer
Dim source
Dim WsTo As Worksheet, WsFrom As Worksheet
'Get the name of this workbook
file_name = ThisWorkbook.FullName
'Gets the source of the Source file
source = Excel.Application.GetOpenFilename( _
Title:="Please choose a file", _
FileFilter:="Excel Files *.xlsx (*.*),")
'Open the source WorkBook
Excel.Application.Workbooks.Open (source)
'Process the source to get only the file name
avarSplit = Split(source, "\")
intIndex = UBound(avarSplit)
source = avarSplit(intIndex)
avarSplit = Split(source, ".")
source = avarSplit(0)
'Create the From and To worksheets
Set WsTo = Workbooks(file_name).Sheets(3)
Set WsFrom = Workbooks(source).Sheets(1)
'Transfer the information from one to another
WsTo.Range("C5", "C11") = WsFrom.Range("B9", "B15").Value
WsTo.Range("D5", "D11") = WsFrom.Range("C9", "C15").Value
WsTo.Range("E5", "E11") = WsFrom.Range("D9", "D15").Value
WsTo.Range("F5", "F11") = WsFrom.Range("E9", "E15").Value
WsTo.Range("G5", "G11") = WsFrom.Range("F9", "F15").Value
WsTo.Range("H5", "H11") = WsFrom.Range("G9", "G15").Value
WsTo.Range("I5", "I11") = WsFrom.Range("H9", "H15").Value
WsTo.Range("J5", "J11") = WsFrom.Range("I9", "I15").Value
WsTo.Range("K5", "K11") = WsFrom.Range("J9", "J15").Value
WsTo.Range("L5", "L11") = WsFrom.Range("K9", "K15").Value
'Close the openned source file
Excel.Application.Workbooks(source).Close
End Sub
I hope someone can help.
Thanks!!!
JessBononi (BOB member since 2012-05-31)
