Upon clicking on refresh, the users need to select to run the report on criteria A, B or C. We need to alter a dataprovider’s filters (where clause) according to the user’s selection.
We need to add two or three conditions seperated by OR.
We looked into the code ActiveDocument.DataProviders.item(1).Queries.item(1).Conditions.Add “Test Class”, “TestObject”, “Matches Pattern”, “QO%”, “Constant” but idd not manage to get it to work.
Anyone can help on this please? It really is important…
Not sure if this would help, but we used the following to add ‘predefined’ conditions to a given dataprovider.
Sub AddCondition()
Dim oDoc As Document
Dim DPConditions As Conditions
Dim AllDPs As DataProviders
Dim CurrentDP As DataProvider
Dim strUniverseName As String
Dim DpCount As Integer
Dim x As Integer
Dim strPredefinedCond As String
Dim strClass As String
strUniverseName = "MyUniverse"
strPredefinedCond = "MyConditionName"
strClass = "MyClass"
Set oDoc = ThisDocument
Set AllDPs = ThisDocument.DataProviders
DpCount = oDoc.DataProviders.Count
For x = 1 To DpCount
Set CurrentDP = AllDPs.Item(x)
If CurrentDP.GetType = UCase(Trim("DPQTC")) Then
CurrentDP.Load
Set DPConditions = CurrentDP.Queries.Item(1).Conditions
strUniverseName = CurrentDP.Universe
If UCase(Trim(strUniverseName)) = "MyUniverse" Then
Call DPConditions.Add(strClass, strPredefinedCond)
End If
CurrentDP.Unload
End If
Next x
End Sub
