VBA Documentation
Does anyone know if Business Objects has documentation on writing VBA code in Excel?
I have downloaded the SDK documentation for Component, Data Access, Enterprise Java, & Report Engine SDK. However, all appear to be Java code documentation rather than VBA code documentation.
:stupid:
I’m an Admin, so I have all the Reference libraries needed, but just can’t find any VBA documentation.
I have used a number of Excel VBA downloads and I can figure out the code, but would like to learn more about the VBA libraries and code.
bdiss :us: (BOB member since 2007-12-05)
Go to help.sap.com, under Business Objects section.
If you’re using XI3.1, select BO Enterprise, version 3.1 and search the word COM through the list below.
In case you’re using XIr2, go to:
http://devlibrary.businessobjects.com/BusinessObjectsXIR2/en/devsuite.htm
and open the “Universe Designer and Desktop Intelligence SDKs” link on the left frame.
CLS69 :it: (BOB member since 2009-06-11)
