Hi BOB,
I’ve a requirement where I need to compare the 2 dataproviders based upon some criteria. If the condition is satisfied then only report has to fire other wise it has to send an e-mail to the corresponding authority. All the above process should run only AfterDocument Refresh procedure. I’ve the script for e-mailing. Any of you please provide me the script for comparing two dataproviders using VB macro.
Thanks in advance.
dattatreya (BOB member since 2004-06-28)
