In BO XI 3.1 SP6.3 @variable(‘UNVID’) exists that returns the ID of the universe object.
I am a bit confused under what circumstances it shows a Universe ID.
When the variable is queried in a Web Intelligence report, it shows the Universe ID from a BO repository the report was originally saved to. If you open the report in a different repository - even after it had been exported to that repository - it still shows the original ID.
The only way I seem to resolve it, is by manually re-attaching the report data provider to the universe. Only then BO shows the correct Universe ID that is applicable for the different repository.
I wonder if other people had similar issues and have found a better workaround for it.
Thanks for pointing me to the ‘unbound report’-blog, Mak I.
A Universe having a different CUID in different repositories could be a logical cause for @variable(‘UNVID’) not displaying a correct value.
I did conduct a small test by exporting a Universe from repository X to a BIAR-file using the Import Wizard. In repository Y I then imported the file. After this step the Universe did exist in both repositories sharing the same CUID.
Unfortunately, querying @variable(‘UNVID’) in a Web Intelligence report then still behaves as described in my original mail. Explicitly re-attaching the report data provider to the universe is the only solution.
Maybe the @variable(‘UNVID’) will behave differently in BO XI 4.x. Until then, I will write instructions for my colleagues whenever a BO XI 3.1 Web Intelligence report needs to be migrated from one repository to the other, to explicitly re-attach each data provider to the universe.
In repository X I created a Web Intelligence report consisting of an object using @variable(‘UNVID’). Refreshing it in repository X InfoView it returns the repository X Universe ID.
With the Import Wizard I exported the report to a BIAR-file and imported it in repository Y. Refreshing it in repository Y InfoView it still returns the repository X Universe ID.
Only after having manually edited the report data provider by having it re-pointed to the same universe-name, repository Y Universe ID is shown.
Very strange. It still seems to me that the queries have become unbound in some way. As I said the CUIDs should persist from environment to environment, ie. they should be the same.
