We have a connection set up which uses @variable(‘BOUSER’) to access our oracle warehouse. It works in the old UNV universe. But if I open the exact same connection in the IDT interface, it won’t connect and gives me an “invalid username/password” error.
Try with the user name as the end users will use so they have put BOUSER. you can your client and he will provide you. We got the same situation in freehand sql in 3.1
No explanation. Something to do with being able to use “Business Objects Credential Mapping” instead, which doesn’t really help in our case. Need to get our DBA onto it as we’re currently using oracle to handle the security side and I don’t know what I’m talking about!
