system
January 23, 2015, 4:04pm
1
I have a input field input_col of data type VARCHAR(17) which is to be loaded into the field of data type DECIMAL(16,8).
I used the BODS function: to_decimal_ext(input_col,’,’,’.’,16,8)
Decimal Sep: Comma
Thousands Sep: Dot
But when the job runs it is failing due to Numeric value out of range error.
eg: if the input value given is : 1.658
The job fails giving the below error.
Failed in “out_col_name” column with the value 165800000.00000000.
Can someone please tell me why is BODS generating 165800000.00000000 which is of the precision/scale of (17,8) instead of 1.658,00000000
Is it because I am using DOT “.” as thousands seperator in input but as thousands seperator in output.Will this be an issue.
Thank You
MaveriK (BOB member since 2012-02-26)
system
January 23, 2015, 8:23pm
2
Have you tried cast function?
Cast (colname, ‘decimal(16,8)’)
Arun.K (BOB member since 2011-10-18)
system
January 24, 2015, 6:44pm
3
The input has decimal separator as dot and thousands separator as comma. While the output has vice versa. How can I modify it using cast?
system
January 26, 2015, 12:46pm
4
Will like to know if you have found the solution…
BOBJFan (BOB member since 2011-09-24)
system
January 26, 2015, 2:52pm
5
Try this
cast(replace(‘col_name’,’,’,’.’), decimal(16,8))
system
January 27, 2015, 7:21am
6
Thank you Arun. The conversion runs successfully with the cast option you have suggested.
But is there any reason why the function to_decimal_ext is not doing the intended conversion and causing errors.
system
January 27, 2015, 3:01pm
7
Have you tried with to_decimal instead of to_decimal_ext()? Because the to_decimal_ext() will add precision as parameter.
