Using WHERE clause in Formula/Variable
Hello,
I am facing a problem where i need to calculate count of id depending upon the status of a column. e.g. I am using a formula in my variable like this:
=Count() Where (=“RED”)
Now i have to count the IDs for the status RED/BLUE/GREEN and YELLOW. So when I try to give something like this
=Count() Where (in (“RED”,“BLUE”,“GREEN”,“YELLOW”)) then it shows me syntax error DMB0007.
I am using BO 5i.
Thanks to please help me on this.
sanbatra :india: (BOB member since 2006-09-29)
sanbatra,
Your ‘error’ is very understandable…
The correct syntax is:
=Count(<ID>) Where (<Status>="RED")
+Count(<ID>) Where (<Status>="BLUE")
+Count(<ID>) Where (<Status>="GREEN")
+Count(<ID>) Where (<Status>="YELLOW")
Nobody knows why BO doesn’t accept: ‘<’, ‘<=’, ‘>’, ‘=>’, ‘<>’, ‘inlist’, etc… only ‘=’ is accepted :wah:
Hope this helps,
Johan
JdVries :netherlands: (BOB member since 2006-02-06)
I tend to use If…Then…Else instead of Where…just works better for me.
Nick,
You mean something like
=Sum(If (<Status> InList ("RED","BLUE","GREEN","YELLOW")) Then 1 Else 0)
This works, but now the object must be somewhere (hidden) in the table else an error will occur :hb:
Hope this helps,
Johan
