using unstr and substr and upper
I have an object…
  1. convert to upper case (which I have done)
    upper(EMPLOYEEID)
  2. The ID’s are displayed like this: nt domain\joe bloggs
What I want to do is chop on the gighlighted bit. But the thing is the number of characters to be chopped will vary as the domains could differ so really what I want to say is 'chop off everything after the “/”.
any idea how to do this using instr and substr?
prishma123 (BOB member since 2010-02-22)
Try below syntax …
substr(EMPLOYEEID,1,(instr(EMPLOYEEID,’’)-1))
pravin_gaikwad :india: (BOB member since 2010-03-27)
hi, the sytax works but it returns the first few char before the /. for example, it return domain but I want tit to return everything after the slash. Full field is domain\user id so I want to retun only the user id
hi ,
I hope follwing syntax will work as per ur requirement
substr(EMPLOYEEID,(instr(EMPLOYEEID,’’)+1))
thanks it works a treat
