Using union to create a derived table
I have a table made this way:
Matter_ID    Name      Type
1090           ABC         primary business unit
1090           XYZ         participating business unit
I want it to be like this to serve my reporting:
Matter_ID    Primary_B_U      Participating_B_U
1090           ABC                   XYZ
So, I thaught of using a union to make this work
Here is the exact code that I have created:
select
dbo.MatterPlayer.MatterNumber_ID,
dbo.Entity.Name as Participating_Business_Unit,
null as Primary_Business_Unit
From dbo.Entity
INNER JOIN dbo.MatterPlayer ON ( dbo.Entity.Entity_EID = dbo.MatterPlayer.Entity_EID AND dbo.MatterPlayer.Role_CD = 'Participating Business Unit' )
union
select
null as Participating_Business_Unit,
dbo.Entity.Name as Primary_Business_Unit
From dbo.Entity
INNER JOIN dbo.MatterPlayer ON ( dbo.Entity.Entity_EID = dbo.MatterPlayer.Entity_EID AND dbo.MatterPlayer.Role_CD = 'Primary Business Unit' )
I dont understant why my results are like this:
1090                                    XYZ
1090            ABC
can you please tell me if I m wrong with some points
zizou :tunisia: (BOB member since 2008-07-31)
Quick question…do you have a need to do this at the universe level ?
Have you considered doing this at the report level, using 2 data proiders and merging the 2 on Matter ID ?
BTW…the union is doing what it is supposed to do, eleminating duplicates and in your case there are not really any duplicate rows.
What you need is a join and not union…
If you want to stick to derived tables try creating 2 derived tables (one for participating Bu and the other for primary BU) and joining the 2.
Naresh Ganatra :us: (BOB member since 2004-04-09)
Hello
Your question is excellent! The situation now is like that. My clients have to do two queries everytime the want to make report as simple as this:
Section = primary business unit
Bloc: Matter, Participating business unit.
Now my clients are unhappy(very!). I understand that it should be done at the universe level (as it is not done at the data base level).
You need to pivot the data, the general idea would be as follows
select MatterNumber_ID,
         max(case when Role_cd='Participating Business Unit' then Entity.Name else null end),
         max(case when Role_cd = 'Primary Business Unit' then Entity.Name else null end)
from <your tables, joins, etc.>
group by MatterNumber_ID
jwhite9 :us: (BOB member since 2006-07-28)
Juste tried it and it worked veeeeeeeeeeeeery Fine! thank you for your idea
