I have a universe with 181 classes, 3040 objects, 46 conditions, 115 tables and 76 alias tables. Each one of my database tables has two common columns: “Entity Id” and “Area Id”. For example, I have users that I want them only to see data that has an Entity Id = “HBUS” and an Area Id = “US”. Then I have another set of users that I only want them to see data with an Entity Id = “HBCA” and an Area ID = “CA”. I know how to use row restrictions in Supervisor and to establish the necessary groups. I have done this already in Supervisor 5.1.6. However, my users are generating complicated SQL with 4 or more where clauses from the row restrictions and their queries are hanging. Please see the enclosed SQL as an example of a query that hangs.
SELECT
OPS905P.CDW_CUST.TOT_RELN_ID,
OPS905P.CDW_CUST.TRC_NME,
OPS905P.CDW_CUST.CUST_NME,
OPS905P.CDW_CUST.CIN_CUST_ID,
OPS905P.CDW_CUST.FNL_CUST_RISK_GR,
OPS905P.CDW_CUST.CTRY_CDE_OF_INC,
OPS905P.CDW_CUST.CTRY_CDE_PRIN_OPER,
OPS905P.CDW_CUST.CC_ID,
OPS905P.CDW_REFCDE_VT_RMGR.REFCDE_DESC,
OPS905P.CDW_CUST.SIC_CDE_1,
OPS905P.CDW_REFCDE_VT_SICD.REFCDE_DESC,
OPS905P.CDW_FCL_STUB.FCL_ID,
OPS905P.CDW_FCL.FCL_RM_CDE,
OPS905P.CDW_FCL.CC_ID,
REFCDE_VT_CCTR_FCL.REFCDE_DESC,
OPS905P.CDW_FCL.FCL_TYP_CDE,
OPS905P.CDW_FCL.FCL_STA_CDE,
OPS905P.CDW_FCL.FCL_GRD,
OPS905P.CDW_FCL.LOSS_GVN_DFLT_FAC,
OPS905P.CDW_FCL.ORIG_APPR_DTE,
OPS905P.CDW_FCL.NEXT_REVW_DTE,
OPS905P.CDW_FCL.FCL_EXPR_DTE,
REFCDE_VT_CCTR_FCL.CCTR_LGL_HIER_CDE,
OPS905P.CDW_CUST.PRNT_PER_LGL_HIER,
OPS905P.CDW_FCL.ULT_RISK_CTRY_CDE,
OPS905P.CDW_CUST_FCL_ASGN.BUS_ROLE_CDE,
REF_CTRY_CUST_INC.REFCDE_DESC,
REF_CTRY_CUST_OPER.REFCDE_DESC,
OPS905P.CDW_CUST.ENTY_ID,
OPS905P.CDW_CUST.AREA_ID,
sum(case when substr(OPS905P.CDW_FCL.FCL_ID, 8,3) = ‘000’ or left(OPS905P.CDW_FCL.FCL_ID,1) between ‘A’ and ‘Z’ then OPS905P.CDW_FCL_BAL.FCL_MAX_EXP / 100 else 0 end)
FROM
OPS905P.CDW_CUST_STUB LEFT OUTER JOIN OPS905P.CDW_CUST ON OPS905P.CDW_CUST_STUB.ENTY_ID=OPS905P.CDW_CUST.ENTY_ID and
OPS905P.CDW_CUST_STUB.AREA_ID=OPS905P.CDW_CUST.AREA_ID and
OPS905P.CDW_CUST_STUB.CUST_ID=OPS905P.CDW_CUST.CUST_ID and
((char(OPS905P.CDW_CUST.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = ‘’
THEN ‘9999-12-31’ END )
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(OPS905P.CDW_CUST.EFF_DTE) and
char(OPS905P.CDW_CUST.EXPR_DTE))
LEFT OUTER JOIN OPS905P.CDW_REFCDE_VT_CTRY REF_CTRY_CUST_INC ON REF_CTRY_CUST_INC.ENTY_ID=OPS905P.CDW_CUST.ENTY_ID and REF_CTRY_CUST_INC.AREA_ID=OPS905P.CDW_CUST.AREA_ID and REF_CTRY_CUST_INC.REFCDE_VAL=OPS905P.CDW_CUST.CTRY_CDE_OF_INC and ((char(REF_CTRY_CUST_INC.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = '’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(REF_CTRY_CUST_INC.EFF_DTE) and
char(REF_CTRY_CUST_INC.EXPR_DTE)) LEFT OUTER JOIN OPS905P.CDW_REFCDE_VT_RMGR ON OPS905P.CDW_REFCDE_VT_RMGR.ENTY_ID=OPS905P.CDW_CUST.ENTY_ID and OPS905P.CDW_REFCDE_VT_RMGR.AREA_ID=OPS905P.CDW_CUST.AREA_ID and OPS905P.CDW_REFCDE_VT_RMGR.REFCDE_VAL=OPS905P.CDW_CUST.RM_CDE and ((char(OPS905P.CDW_REFCDE_VT_RMGR.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = ‘’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(OPS905P.CDW_REFCDE_VT_RMGR.EFF_DTE) and
char(OPS905P.CDW_REFCDE_VT_RMGR.EXPR_DTE)) LEFT OUTER JOIN OPS905P.CDW_REFCDE_VT_CTRY REF_CTRY_CUST_OPER ON REF_CTRY_CUST_OPER.ENTY_ID=OPS905P.CDW_CUST.ENTY_ID and REF_CTRY_CUST_OPER.AREA_ID=OPS905P.CDW_CUST.AREA_ID and REF_CTRY_CUST_OPER.REFCDE_VAL=OPS905P.CDW_CUST.CTRY_CDE_PRIN_OPER and ((char(REF_CTRY_CUST_OPER.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = '’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(REF_CTRY_CUST_OPER.EFF_DTE) and
char(REF_CTRY_CUST_OPER.EXPR_DTE)) LEFT OUTER JOIN OPS905P.CDW_REFCDE_VT_SICD ON OPS905P.CDW_REFCDE_VT_SICD.ENTY_ID=OPS905P.CDW_CUST.ENTY_ID and OPS905P.CDW_REFCDE_VT_SICD.AREA_ID=OPS905P.CDW_CUST.AREA_ID and OPS905P.CDW_REFCDE_VT_SICD.REFCDE_VAL=OPS905P.CDW_CUST.SIC_CDE_1 and ((char(OPS905P.CDW_REFCDE_VT_SICD.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = ‘’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(OPS905P.CDW_REFCDE_VT_SICD.EFF_DTE) and
char(OPS905P.CDW_REFCDE_VT_SICD.EXPR_DTE)),
OPS905P.CDW_CUST_FCL_ASGN,
OPS905P.CDW_FCL_STUB LEFT OUTER JOIN OPS905P.CDW_FCL ON OPS905P.CDW_FCL.ENTY_ID=OPS905P.CDW_FCL_STUB.ENTY_ID and OPS905P.CDW_FCL.AREA_ID=OPS905P.CDW_FCL_STUB.AREA_ID and OPS905P.CDW_FCL.FCL_ID=OPS905P.CDW_FCL_STUB.FCL_ID and ((char(OPS905P.CDW_FCL.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = '’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(OPS905P.CDW_FCL.EFF_DTE) and
char(OPS905P.CDW_FCL.EXPR_DTE))
LEFT OUTER JOIN OPS905P.CDW_REFCDE_VT_CCTR REFCDE_VT_CCTR_FCL ON OPS905P.CDW_FCL.ENTY_ID=REFCDE_VT_CCTR_FCL.ENTY_ID and OPS905P.CDW_FCL.AREA_ID=REFCDE_VT_CCTR_FCL.AREA_ID and OPS905P.CDW_FCL.CC_ID=REFCDE_VT_CCTR_FCL.REFCDE_VAL and ((char(REFCDE_VT_CCTR_FCL.EXPR_DTE) >= CASE WHEN @PROMPT('Enter Date (format YYYY-MM-DD) or * for Current Date','C',,,) = '*'
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(REFCDE_VT_CCTR_FCL.EFF_DTE) and
char(REFCDE_VT_CCTR_FCL.EXPR_DTE)) LEFT OUTER JOIN OPS905P.CDW_FCL_BAL ON OPS905P.CDW_FCL_BAL.ENTY_ID=OPS905P.CDW_FCL_STUB.ENTY_ID and OPS905P.CDW_FCL_BAL.AREA_ID=OPS905P.CDW_FCL_STUB.AREA_ID and OPS905P.CDW_FCL_BAL.FCL_ID=OPS905P.CDW_FCL_STUB.FCL_ID and ((char(OPS905P.CDW_FCL_BAL.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = ‘’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(OPS905P.CDW_FCL_BAL.EFF_DTE) and
char(OPS905P.CDW_FCL_BAL.EXPR_DTE))
WHERE
( OPS905P.CDW_FCL_STUB.FCL_ID=OPS905P.CDW_CUST_FCL_ASGN.FCL_ID and OPS905P.CDW_FCL_STUB.ENTY_ID=OPS905P.CDW_CUST_FCL_ASGN.FCL_ENTY_ID and OPS905P.CDW_FCL_STUB.AREA_ID=OPS905P.CDW_CUST_FCL_ASGN.FCL_AREA_ID and ((char(OPS905P.CDW_CUST_FCL_ASGN.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = '’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(OPS905P.CDW_CUST_FCL_ASGN.EFF_DTE) and
char(OPS905P.CDW_CUST_FCL_ASGN.EXPR_DTE)) )
AND ( OPS905P.CDW_CUST_STUB.CUST_ID=OPS905P.CDW_CUST_FCL_ASGN.CUST_ID and OPS905P.CDW_CUST_STUB.ENTY_ID=OPS905P.CDW_CUST_FCL_ASGN.CUST_ENTY_ID and OPS905P.CDW_CUST_STUB.AREA_ID=OPS905P.CDW_CUST_FCL_ASGN.CUST_AREA_ID and ((char(OPS905P.CDW_CUST_FCL_ASGN.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = ‘’
AND ( ((char(OPS905P.CDW_FCL_STUB.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = '’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(OPS905P.CDW_FCL_STUB.EFF_DTE) and
char(OPS905P.CDW_FCL_STUB.EXPR_DTE)) )
AND ( ((char(OPS905P.CDW_CUST_STUB.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = ‘’
OR @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) BETWEEN char(OPS905P.CDW_CUST_STUB.EFF_DTE) and
char(OPS905P.CDW_CUST_STUB.EXPR_DTE)) )
AND ( REF_CTRY_CUST_INC.ENTY_ID = ‘HBUS’ ) and ( REF_CTRY_CUST_INC.AREA_ID = ‘US’ ) and ( ((char(REF_CTRY_CUST_INC.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = '’
char(REF_CTRY_CUST_INC.EXPR_DTE)) )
AND ( REF_CTRY_CUST_OPER.ENTY_ID = ‘HBUS’ ) and ( REF_CTRY_CUST_OPER.AREA_ID = ‘US’ ) and ( ((char(REF_CTRY_CUST_OPER.EXPR_DTE) >= CASE WHEN @PROMPT(‘Enter Date (format YYYY-MM-DD) or * for Current Date’,‘C’,) = ‘*’
char(REF_CTRY_CUST_OPER.EXPR_DTE)) )
GROUP BY
I am told by my DBA that Entity Id and Area Id are indexed fields. My question is this: Is there anyone out there who is using row restrictions effectively and efficiently on a large-scale universe like this? Also, will these row restrictions work for WEBI 2.7 users as well? Please help. Thanks.Ken
k685828 (BOB member since 2004-12-15)
(BOB member since 2002-09-19)
