Using Report Viewer 1.0
I’m looking for some help from all the B.O. gurus out there. We currently imbed Business Objects 4.1 in a VB application and with 5.0, wanted to use Report Viewer to replace the current way of doing things. However, I have done some checking and it looks like Report Viewer can only be used to access reports in a repository. Is that true? We do not currently use a repository, so if we really want to use this functionality, we may have to start using one. Any help or direction will be greatly appreciated.
Marian Cooney
McKessonHBOC
Malvern, PA
I guess Report viewer can pull documents only thru WebI.
We also have similar rquirement of viewing BO reports from VB. We did some research and gave up the idea of using that.
Finally we are using scaled down version of BO full client for viewing. Using BO SDK we remove all the unwanted menu items and tool bar items from BO. From Visual Basic we start BO and customize the desktop. That works pretty fine.
Problems with Report Viewer are:
It does not maintain all the formatting mainly fonts. It doesn’t print properly.
Vasan
Marian.Cooney@HBOC.COM on 04/20/2000 03:30:32 PM
Marian Cooney
McKessonHBOC
Malvern, PA
******************************************************************************* Note: The information contained in this message may be privileged and confidential and protected from disclosure. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer. Thank you. Ernst & Young LLP
