system
June 16, 2011, 8:05am
1
Hi all,
I am trying to use the Instr function in Oracle in order to extract the folder part,in order to do that i need to get rid of the ‘’ sign but to keep the text between every ‘’ sign.
Example:
folder_part1\folder_part2\folder_part3\
The outcome should look like:
folder_part1
folder_part2
folder_part3
Any ideas ?
Yoav
yohab (BOB member since 2003-12-24)
MarkP
June 16, 2011, 8:19am
2
If you want it output as three separate rows, you will need to do so at the database level unless there is always a known maximum number of options.
system
June 16, 2011, 8:26am
3
The result can appear as a separate column.
I have maximum 10 positions of the folder path.
Yoav
MarkP
June 16, 2011, 8:28am
4
It will get a bit messy with 10, but have a read through this thread; Dave’s post should help:
Hello
I have trawled the internet and this site and tried (unsucessfully) to split the pipe delimited field that I have into separate fields.
So far, thanks to some code that I found on google, I have managed to get the last 2 values, and can get the first, It is just all the bits in the middle that I seem to be getting stuck with.
I am using a SQL Server 2008 database and would, ideally, like this to be a Universe solution rather than using substring and Pos in the report itself.
Here is wh…
system
June 16, 2011, 9:04am
5
Thanks Mark,
i am looking for a similar logic in Oracle
i’ll see if i can implement it in Oracle.
Yoav
system
June 16, 2011, 11:41am
6
This is code i used:
SELECT regexp_substr(pth,’[^]+’,1,1)
,regexp_substr(pth,’[^]+’,2,2)
,regexp_substr(pth,’[^]+’,3,3)
add as many pieces you need if you have a longer text that need to be separated.
Yoav
