both reports re in full client
the functionality i want to implement is
in first report when i click on Category it should open another report which has a prompt on Year “Enter Planning Year”
now i want to force the Year to 2005 only
when when i am doing that with the above syntax its always asking me to enter the promp value … how can i force the year value directly
any advice is appreciated
thankyou
But you’re running this in WebI / Infoview, right? The openDocument syntax may vary by version – so please tell us which version of WebI you are using, and a moderator will move this to the correct forum.
i am using both as full client reports at the moment opening it in infoview.
i am planning to implement same thing in webI as well
i am using BO 5.1.7 and webI 2X.
my main issue is that its opening the document but its not forceing the prompt to 2005
Moving from “Building Reports” --> BusinessObjects Classic sub-forum to WebI 1.x/2.x sub-forum.
Could the problem be that your prompt text has spaces? I remember when I played with OpenDocument syntax 3 or 4years ago that prompt text with spaces was problematic. I do not remember what you might have to do to deal with it.
And, is your 2005 supposed to be numeric or alpha? If alpha, you might have to force quote marks around it somehow. Again, it’s been too many years for me to remember what I experimeted with – but if you search in this forum for OpenDocument, you’ll find past discussions that may help you out.[/img]
i have looked into the prompt and its fine there is no problem with the spaces,
when i want to force a value to prompt in the report i may say
IsS= if numeric
IsS=’’ if alphabetic
hi anita
it still is not picking up the value automatically its prompting me to enter the value
this is my syntax for the variable and it is charector and i have checked object format as HTML
I’m really sorry, but I don’t have the time to spare debugging this one for you. Let me make some suggestions:
1.) Compare your syntax to the hyperlink I’d given you, to make sure you have it right.
2.) Make sure the spelling of your prompts are identical to those in the report.
3.) Even though you think spaces aren’t a problem, try changing your prompt text (and they URL) to something without spaces, and see if that makes a difference.
I struggled with it when I experimented with it – and haven’t used it in a very long time (3+ years). I remember that I ended up with prompts without spaces.
I have problem to create link object in Unverse. The version is BO 5.1.7. Webi 2.5.
The syntax I use
‘<A HREF="/wi/bin/iswi.dll/WIGenerator/wigenerator/generator/OpenDocument?sDocName=Testing&sDocType=W&iDocId=4066&sRepo=Development&sOpen=Y&lsMSites:=’ || TABLE_SITE.NAME + ‘" >’ || TABLE_SITE.NAME|| ‘’
When I use this object to create a parent report. I always get ORA-01722: invalid number :-1722. Seems like Oracle DB does not support this link. Please help me out.
As I’d suggested, I can’t completely trouble-shoot this for you. But the colon ( after your &lsMSites looks weird to me. I wonder if that’s throwing the syntax off. Try changing the prompt to eliminate the colon.
If that doesn’t do it, I don’t see anything else that pops out at me.
