Is it possible to create Drill Down reports using Crystal? I am only aware of how it is set up in Business Objects, but dont know if/how to set it up using crystal. Would appreciate if someone can point me to some links or books on crystal
Create a report based on groups. This will automatically create the drill down rpt. When you preview the report, double click over the group. this will take you to the drill down data. Hope this helps.
