Is there a way to use the existing connection(universe) to use the data source as “query using sql”? Because while refreshing the dashboard using sql requires password from the users. How can we avoid this?
psk (BOB member since 2004-08-04)
Not sure I understand the question, but anytime you want to bypass the username/pw, then needs to be setup on the server side.
katullus
(BOB member since 2009-08-21)
When I create a storyboard using SQL, users are asked to enter DB credentials when they refresh the story board in BILaunchpad.
How can we setup in server?
Kinda depends on the database. If you are using MS-SQL. The database credentials could be set up using Windows Authentication. But I think that requires AD accounts. I do not know how it is done with other databases.
kevlray
(BOB member since 2010-06-23)
