Has anyone successfully created their own style and used components from more than one within it?
As an example, I would like to create a style called New and use all of the components from Aero apart from the accordion menu from Nova.
I have had a look in (and played a little with) the program files on my local install and it seems that chart.css and art.css sheets within the assets\styles control the skinning of these elements and it seems that it should be simple to point to another style?
I note that there are also art.swf or chart.swf…do these need to be changed too?
Update:- a number of views but no replies…think this is a no.
Have had some limited success working on the style sheets but they are a bit of a mess.
simple_simon (BOB member since 2007-09-05)
