Using a sum of a block in a formula or variable of
          another block.
Greetings BO community,
In one block I have calculated the Revenue per account with the total
revenue in the footer of the block (as a sum aggregate).
I now need to use this Total Revenue to build another block in which the
Expenses are represented as a % of Total Revenue for each account, i.o.w.
the formula is Expense/Total Revenue. How can I define this Total Revenue to
obtain this. If Total Revenue could be defined as a constant I could simply
create a nother variable like ExpensePerCent=Expense/TotalRevenue (with
Expense being the only object). But this is not possible I guess.
Any help much appreciated.
Guy Zelck
(guy.zelck@eds.com)
