Using a sum of a block in a formula or variable of another
Greetings BO community,
In one block I have calculated the Revenue per account with the total revenue in the footer of the block (as a sum aggregate). I now need to use this Total Revenue to build another block in which the Expenses are represented as a % of Total Revenue for each account, i.o.w. the formula is Expense/Total Revenue. How can I define this Total Revenue to obtain this. If Total Revenue could be defined as a constant I could simply create a nother variable like ExpensePerCent=Expense/TotalRevenue (with Expense being the only object). But this is not possible I guess. Any help much appreciated.
Guy Zelck
(guy.zelck@eds.com)
ock.
in first block, you’ll simply display, , and Sum() in the footer.
In second block you display , , where =/Sum(Revenue) ForAll
– Vasan
block.
Guy Zelck
(guy.zelck@eds.com)
          another bl
          ock.
– Vasan
-----Original Message-----
Sent: Tuesday, December 22, 1998 7:19 AM
block.
to
simply
Guy Zelck
(guy.zelck@eds.com)
