I am designing a job in DI that needs to take data from a LONG datatype column in the source schema and map it to a to a LONG datatype column in the target schema. I have realised that I cannot do this as I am using a database function in the query transform that tries to do something with the LONG datatype, and LONG datatypes cannot be used in Oracle PL/SQL functions. So in order to get round this, I tried changed the function to use VARCHAR2 instead of LONG. I have estimated though that I would need DI to handle a VARCHAR2(8000) datatype as I am trying to concatenate two VARCHAR2(4000) types in the query transform and then ultimately put this in a LONG type column in the target schema. But DI has problems handling anything over VARCHAR2(4000), so this is a problem. DI also does not handle LOBs, which would be a way round the function problem I have with LONGs. Is there anything I can do in DI to solve this problem?
dataintegrator.net (BOB member since 2006-01-12)
