use of inlist and matches pattern in same query
I have a request from a customer to have a report that they can either enter a matches pattern or in list as an answer to a prompt. The report would be broken down by 3 different selectable entities. So they could enter either for the prompts for association, group code, or department number. Initial thought was they could enter a % where they wanted all and the in list would handle a limited list.
Ideally I would want to set the variables up in an “Or” statement within the query. It will be a full client report but refreshable on WEBI. Issue I have been running into is that matches pattern is a mono verses the multi I need for the in list.
mmurray (BOB member since 2003-01-13)
Hi Mike,
Take a look at this post for starters
irish_stan :ireland: (BOB member since 2003-05-13)
The issue with using the LOV is there could be hundreds of them. An example of what they are trying to do is.
Enter Group number:
If the wanted all groups in Iowa and groups were all prefixed by the state abbreviation followed by a number they could enter IA as a pattern to match and would get all IAxxxx groups back.
If there was a group in every county that would return 99 rows. But if they only wanted two adjacent counties they would enter IA1234;IA1256. If they wanted all groups they could enter %.
Then this type of logic would continue with the other criteria
You’re on the right path. The problem is that BO doesn’t do optional prompts.
The limit of inlist and wildcard is not a BO one, it’s a SQL one.
I also have a case where I want to allow the user to enter either
single value, multiple values, partial value (e.g, CH%) or % for all.
Steve, I am not sure I understand your post. Are you saying that this is not possible to do?
ciodice :us: (BOB member since 2005-04-05)
What I’m saying is that you can’t have a sql statement that accepts a wilcard within with an IN operator.
You need to try to generate something like:
Where
table.column in @prompt(…,multi, free) OR
table.column like @prompt(…,mono, free) OR
‘ALL’ in @prompt(…,multi, free) OR
The question is this: can you use the same prompt with different parameters? I don’t have time to check this out right now. Try it and let us know.
I wasn’t able to do it.
I was able to get a single value, pattern matching and % for all. However, when I selected multiple values I received the following error:
Connection or SQL Sentence Error DA0005
any ideas anyone?
What are the details of the error? When I see that error, I get a “details” button, and when I click on the Details, a more descriptive message appears.
KSG :us: (BOB member since 2002-07-17)
Here are the details:
Exception: DBD, ORA-00907: missing right parenthesis
State: N/A
You may want to post the SQL you used. This sounds like a syntax issue.
