The report is a sales report for items. We divide items into product groups. So say for example I have CBL which is a product group for all Cable products, NET is a product group of all network products.
Part to Product group is 1:1
I want the report to allow the user to enter either Product Group or Items ans also allow them to use Values from LOV or enter a wild card for all.
So I have two prompts:
Product Group IN list Prompt (‘Select Product Group from Values’)
AND
Items Matches Pattern Prompt(‘Select Items or use % for wild card’)
Scenario 1: I want to run report by entering Poduct Group: This works fine, I type or select a Product Group, and since Items is matches pattern, I can enter % for all (Oracle)
Scenario 2: I want to run a report for all Items that are like ‘H7g%’
I cannot do this since Product Group uses In List. Is there a way to use a radio button kind of selection, where a user is either selecting a Product group or entering item pattern?
OR be able to say:
PRODUCT GROUP MATCHES PATTERN OR IN LIST (in a single condition) and not in two separate conditions
I know it can be done by VBA, but I want to avoid writing extra code if BO has something built in…
