can i install both version at same client?
what can i do?
install BO-XI at first before install BO6.1b
or install BO6.1b and install BO_XI
who ever tried to installed and working?
Perform client installation of BO v6 first. Then install BO XI. When doing the latter installation do not forget the following:
there is a step where you need to specify the destination folder. Be sure not to install BO XI into the same folder where you installed BO v6
there is a step where you will be asked “would you like to migrate your previous Desktop Intelligence settings?” - you need to select NO. This will keep your Bo v6 reports untouched.
The rest is just straightforward installation process.
