I’m having problems in creating a report that mimics a sql script that I’m directly running against sql server 2000.
So my workaround was to us Free-Hand Sql. Problem is i’m trying to do a query from two different databases. B.O. would only let me put in one database connection.
Here’s my sample script:
select distinct a.id, a.date_start, t.xnumb
from transaction1 as t
inner join account as a ON t.acct_id = a.id
where a.date_start between ‘8/1/02’ and ‘9/1/02’
and a.acct_type = 2
and exists (select 1 from crm_prod_02…crm_stg_icon_hist as c
where c.orderid = t.xNumb and
t.transactiontypeid = 1 and
c.sitename like ‘Ar%’ and
c.perfdate is not null)
order by a.date_start
Transaction1 and account tables are on my default db and the crm_stg_icon_hist is on another database.
Thanks in advance.
Hernan
P.S. Hey Michael W., wish I had taken your advance reporting class
If your second database is “reachable” via your first connection, it should still work. In other words, when you define a connection, BusinessObjects get the data it needs to establish a communication with a server / database. (The terms vary from one vendor to another.) If you can connect to the second database using the same connection, using the database.owner.table.column structure instead of just owner.table.column or simply table.column, then you should be fine.
Any numbers that come in a free hand or personal data provider will default to a measure, so BO is aggregating them at the report level. You just need to click on the data cube and change those objects to dimensions if that is what they are supposed to be. I wouldn’t turn off the aggregate duplicate rows unless absolutly neccesary.
Hmm, I just ran some free hand sql and I still had the option. Usually when you run on a Universe you cant change them because that is set at the Universe level.
So, if you click on Data from the formula bar, then click view data, then click on the definition tab. Then click on the field name, you should have the option to change from a measure to a dimension.
Good to know about fields defaulting to a Measure. The fields that are aggregating are account numbers so their safe to convert to dimension. Changing them to Dimension fixed my problem.
