HI,
I am trying to repoint my report to a BO XI 3.1 universe. The report accessed another universe which has to be changed now.
The main problem is whenever i change my datasource location to point to the new universe(has the same name as the old one) all the paramaters are lost.
I am also not able to view the sql behind the old universe which was present in the report, i thought that since the universe names are same i should be ok if i refresh the connection but this is not happening.
Also when i create a parameter in my new report the icon that is present is completely different to the old ones.
Note: these parameters are @PROMPTS which link to the the main filters present in the universe.
monty.cr (BOB member since 2009-11-13)
