BusinessObjects Board
Urgent Help Needed for Webi Report Relative Positioning
Please guyz, I really need help … its urgent …
I am using XIR3.1 SP5
I am not using any sections in my report.
I have a webi report and i have one empty blank text as report header in the report body. below that i have a report block with 5 columns.
i am trying to use relative position for the 2nd block to come beneath the report header cell.
Now i schedule my report with a publication, and select the format as mHTML.
when i receive the report, the header cell is beneath the report block.
Even without any relative positioning also it is the same. thats the reason, i did configured the relative positioning.
i tried creating a brand new report. its still the same :hb:
Please help !!!
Any solution/suggestion is highly appreciated
I have used Relative positioning before, but never had any issues with publication with format mHTML.
sil_bob (BOB member since 2011-12-06)
This thread might help:
HTH
NMG
half way through formatting my report … Almost working Buddy !!!
i dont have enough words to thank you !!!
I will confirm once my whole report is done.
:wave: :+1:
