We are seeing upside down question marks in a field that do not appear in the database. We originally first experienced this issue when testing the report in version 6.5.1. When upgrading our full client environment from 5.1.6 to 5.1.8, the issue has also appeared. This is a critical problem as it affects personnel report.
I am attaching the report so that the problem would be clear.
Thanks in advance.
B…
[Moderator Edit: Note that you can only view this document if you have version 6.x of BusinessObjects. So don’t bother to download the attachment and virus-scan it if you only have version 5.x - AMC]
Same issue here. Thought the universe is internationalized to the dutch, we are getting inverted question mark in the report for the non-english dutch characters.
Please let me know how to do this without changing the DB schema.
