I am testing the upgrade process from 2.4.x to 6.x for Set Analyzer. Supposedly when you run create the connection and open Set Architect for the first time, you are suppose to be prompted for a script. This script creates a new table for SA in 6.x, set_qm_task. However, when I connected to the set repository to make sure everything is fine, I never get prompted to run the script. Anyone out there have any suggestions.
Sheila (BOB member since 2003-09-10)
