Upgrade documentation & HELP!
Folks!
I am up grading from B.O.4.1.3 to 5.0 and webi 2.0.3 to 2.5. I have to upgrade both on the server. Here are my questions:
  1. Does the CD walk you through the install or do you have un-install BO and WEBI from the server first?
  2. Will I be able to use the same repository? For an upgrade I should be able to right?
  3. The supervisor Module, does that update as you run the CD for BO 5?
Any documentation or answers well be appreciated.
Best Regards,
Aris Arefi
Business Objects Support & Development Team U.S. Naval Shipyard, Norfolk Virginia
757-396-3610 Ext. 254
arefia@nnsy.navy.mil
(o)
It is a fresh install in its own subdirectory.
  1. Will I be able to use the same repository? For an upgrade I should be
    able to right?
You run a conversion utility on your repository which then is your 5.0 repository.
  1. The supervisor Module, does that update as you run the CD for BO 5?
Your CD ROM should contain all the documentation in PDF format.
Chris
Thanks Chris,
I will look into it.
Aris
