Is there a way to unpublish, delete or remove published cleansing packages from within Information Steward?
ErikR (BOB member since 2007-01-10)
Theres a delete button up there to do that.
Our admin was expressing concern that they werent actually deleted from the job server though, and they consume quite a lot of space.
jlynn73 (BOB member since 2009-10-27)
I couldn’t see a delete button in the IS application itself, even when logging on as Administrator. But I can delete them through the CMC.
You can delete an unpublished cleansing package from within Information Stewards Cleansing Package Builder. If you want to delete a published cleansing package that needs to be done through CMC. The reason for this is that we want an Administrator to delete a published cleansing package to ensure that a published cleansing package doesn’t get accidently deleted by a user that is actively being used by a Data Services job.
Thank you,
Lynne
lynnel (BOB member since 2010-10-13)
What if IS is not installed on the system, and the Published Cleansing Package was migrated onto the system via Lifecycle Management?
The customer has a run-time only license of Information Steward, which doesn’t allow installation in a Production environment. So no IS components are available.
When viewing the published Cleansing Packages in the CMC under Version Management->Data Quality->Cleansing Packages->Published, the Delete button is grayed out.
Tony
tonymaas1LS (BOB member since 2016-07-20)
