unknown scheduled job
Hello,
some time ago I made a job Job_X_Test.
After running it a while, I deleted this job from my project. Now it is still running every night, despite of that job does not actually exist. Where do I know that it is actually running? Well, I made a little script into that job that sends me the e-mail, if error occures. And now it sends me the error every night. I cannot see the job definition itself in DS management console…
How to fix such mess?
bobmeediake :estonia: (BOB member since 2008-12-01)
Go into the scheduling software for your OS (Windows Task Scheduler under Control Panel, or whatever the equivalent is for LINUX/UNIX), and you should see an “extra” job there, relative to your schedules.
The way to find it: Temporarily disable all schedules in the DI web admin – this removes them in the OS scheduler. So you’d just see the one orphaned job still enabled. Delete that job in the OS scheduler, then re-enable your DI schedules.
Thanks dude!
This made me so many headache. I didnt know that BO uses OS’s scheduler.
I deleted all OS’s and DS-s schedules and then I made new schedules for my job.
After today, I always double check the job entries also in the Scheduled Tasks folder.
Normally, they don’t get out of sync.
But a best practice is, if you have a Job that you have scheduled, be sure to deactivate the schedules, before deleting that Job.
