system
1
1). I need a query(based on metadata) to get list of all Database Schema Names (Data source names) and UserIDs list.
- I need one more query like list of universes with corresponding users in group level.
Thanks & Regards
Prasad.
prasadbi (BOB member since 2006-06-29)
For question 2 have a look to the response here i already gave you.
Could you be more precise for question one please.
You first need all DSN of all your conection
then list of user and their userid ?
system
3
Regarding my 1st and 2nd Question.
I need a query having the information list with following details.
IP Address:
System:
Domain | Connection Name | DB Schema Name | DB User ID | Universe Name | BO User ID (With Group level) | Table used by Universe.
Thanks & Regards
Prasad.
As told in the specified post it’s not possible to have link between user and universes.
You can know :
Domain | Connection Name | Universe Name | Table used by Universe.
For Table used by Universe used managero universe.
DB Schema Name | DB User ID are crypted
system
5
Even it is crypted I need that information for DB Schema Names | DB User IDs. If possible please let me know how to de-crypt.
Thanks & Regards
Prasad.
The only solution i know is to go under supervisor open all connections and manually note these infor;ations !
system
7
Please any one can give answer for my question.
How to get list of DB Schema Name | DB User ID. I think it is crypted. How to de crypted the information.
Thanks & Regards
Prasad.
system
8
@Prasad:
When you have been told that it is not possible, and a way has been shown
then why ask again?
In BO there are certain things exposed, certain data stored in repo, certain NOT. What you need is not possible…!!
If you are not convinced yet, and need support for your issue, Contact BO TECH SUPPORT… they are there…
BO_Chief
(BOB member since 2004-06-06)
An other advice for you: migrate under Xir2 where everything is crypted under the repo db
