Universes Merging - limiting data
I’ve got two Universes:
  1. Orders - I get from here Cell Name, Order Number, Quantity Ordered and Completion Date.
  2. Production Bookings - I can get from here Cell Name, Order Number , Quantity Completed, yet I can’t get Completion Date
I can merge those universes on Cell and Order Number.
Now, if I create report that contains:
Cell - Order Nr - Completion Date - Qty Ord - Qty Completed
  • it works fine, as granularity level is enough, for it to calculate correct Qty Completed.
However, I want also, something like Dashboard, where I have only Cell, Qty Ordered and Qty Completed.
I create query from Orders Universe, where I get orders in date range (user prompt for completion date). I don’t have a way to filter data from Bookings Universe in same manner, so I get all data from that universe. In Report, from Orders Universe I get:
Cell - Qty Ordered
from Bookings Universe I I want Qty Completed, so final version I want:
Cell - Qty Ordered - Qty Completed
Could someone help me create variable for Qty Completed, to sum Qty Completed from Bookings Universe, but only for Order Numbers that were retrieved in Orders Universe.
If I use sum only, it sums all Qty Completed, for all data retrieved from that Universe. I’ve tried some combinations of IN / FOREACH / FORALL, yet neither seems to work. How do I restrict SUM in one universe, based on data from another universe?
Thanks for Help
pit84 (BOB member since 2020-05-12)
Try creating a detail variable with Cell or Order Number as the associated dimension. Then filter you table where that new variable is not null which ensures a match.
