Universes and Explorer
Can you bring in two universes to Explorer or is it just made for a one-on-one deal.
I have information that I need to give the users and even though 1 universe has most of the information there are a couple fields that are not there but exist elsewhere in another universe.
I don’t see any option to bring in another Universe unless I am missing something.
We are using Explorer that came with our purchase of BO 3.2 version
thanks for any and all help
di652 (BOB member since 2005-02-24)
You can only base an Infospace on ONE universe so you would need to do whatever integration necessary on the IDT side - Explorer cannot handle that.
jackie_dunn :us: (BOB member since 2013-09-03)
Thanks I was afraid of that
Especially when users like a WEBI report that uses a few universes for the mutlple tabs.
Not sure I can bring in links to the one universe without causing chaos. Too bad they didn’t think this through about adding multiple dataproviders :frowning:
