Dear All
Here is some code snippet
Here is some snippet from code
Designer.Classes classcoll;
Designer.Class cl;
Designer.object ob;
cl = classcoll.get_FindClass(“ABC”);
Now to navigate through the class the only way i am able to do it is
foreach (Designer.Object ob1 in cl.Objects)
However- i have some huge classes , say 100 objects and this looping takes a hit on performance.
Is there anyway based on object name to just pull in one single object?
Any hints/suggestions much appreciated.
ramaks (BOB member since 2009-03-31)
