All,
I need your help to see what i am missing here. I am doing some development work with Universe SDK. When trying to get objects in a class i run into this error consistently.
Here is some snippet from code
Designer.Classes classcoll;
Designer.Class cl;
Designer.object ob;
cl = classcoll.get_FindClass(“ABC”);
This works fine so far.
However i need to parse through the objects in the class and get their names in string format.
so i do
long cnt = cl.Objects.Count;
Console.WriteLine(" The number of objects in class is " +cnt);
//gives me the number of objects in the class.
when i try to loop through these objects
for ( i = 1; i<= cnt; i++)
ob = cl.Objects.get_Item(i);
Console.WriteLine(ob.Name);
This is where i consistently get this error as shown below.
Any ideas or hints would be greatly appreciated.
The class and the objects do exist.
Console Output :
The number of objects in class is 137
System.Runtime.InteropServices.COMException (0x80004005): no Object found!
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFla
gs flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Designer.IObjects.get_Item(Object Index)
at UniverseUpdate.Class1.Main(String[] args)
ramaks (BOB member since 2009-03-31)
