Hello
I would like to see with you an issue we saw with Xcelsius XI 4.0 SP5 with query on universe :
Dashboard doesn’t display the exact value I have in the database
By searching deeper, i saw this issue is already inside the query results
i expect to have this value : 119411966.84
In the Xcelsius Query preview :
In display formatted value, it is 1.19411968e8 (which is not correct)
In raw values, it is 119411968 (which is not correct also)
and by consequence, value inside the dashboard is not accurate
To make another test, but this time in Webi, using the same universe unx and objects, it shows the correct value in the database: 119411966.84
Did someone solve this kind of issue ?
Thanks in advance
David
guennal (BOB member since 2005-08-30)
