Universe metadata extraction?
Hi Family,
I need to find a particular table in all universes. This question is similar to below post:
https://bobj-board.org/t/85875
But unlike Macro options prescribed, I would like to try by querying the BO repository tables or using Query builder. I’m using BOXIR3 SP5.
Please suggest at the earliest.
Karthik
karthik.prasathkumar (BOB member since 2012-10-21)
If you’re querying the repository tables in XI3 then you need to use query builder in the CMC
Thanks Mark,
Can I get the query to extract the universe which uses a particular table through Query builder?
Best regards,
Karthik
No. The universe metadata is stored in the universe file; this lives in the FRS rather than the CMS, not it’s not possible for a CMS query to get at it. The utilities in Bob’s Downloads are the best bet.
Joe
Thankyou Joe for your comment!!!
Right now, I’m saving each universe as PDF and then searching for the table name in there. Time consuming, but atleast able to achieve the outcome since the universe count is less.
Could you share your thought about getting all the reports which uses a particular table?
Karthik
As Joe suggested, take look in the BOB’s Dowloads forum, there are many tools there that can help you.
jwhite9 :us: (BOB member since 2006-07-28)
