Universe Joins order
Hi all,
I would like to know how can i make universe joining table with specific order.
For example, if I have table A,B,C
i want universe inner join A,C first then outer join B
However, now universe outer join A & B and inner join C
Does it hv any method to set the joining sequence? Thanks.
nicktyk (BOB member since 2010-04-22)
The order will depend upon how you create your joins on Universe. Try this simple exercise:
Drag three tables (A,B,C):
Case 1: Join A - B and then B - C. Export the Universe. Select objects from each class on Webi/Deski. Now look at the SQL generated. You will find:
Select <>
from A, B, C
where A.column = B.column and B.column = C.column
Case 2: Join B - C and then A - B. Export the Universe. Select objects from each class on Webi/Deski. Now look at the SQL generated. You will find:
Select <>
from A, B, C
where B.column = C.column and A.column = B.column
I tried this way back on BO XIR2 :slight_smile:
Rajat Sapru :us: (BOB member since 2008-08-28)
Do you mean that it is just listing joins in a particular order in the Oracle syntax (ie. joins in the WHERE clause), or is it nesting them in the FROM clause? Perhaps you could post the SQL.
slimdave :uk: (BOB member since 2002-09-10)
