Universe join
hi all,
I need to change a join between two tables table1 and table2(alias table).
the existing join is
dbo.table1.field1=table2.field2
the new join looks like below
dbo.table1.FIELD_1 = table2.field2
whereas table1.field1 and table1.FIELD_1 are of same data type. the number of rows returned by these two fields are different.
I want to do impact analysis by changing the table join.
Is there any easy way to check which are the objects created using these tables
can anyone tell me the list of thing that need to be analysed as a part of this…
daffodils (BOB member since 2007-08-09)
So you actually want to document the universe and find which reports are pointing to the objects in the universe
Then have a look into BOB downloads there are utilities for the same
Like List objects in a report
