just one small question: Is there any way to create a universe on CMS to make reports out of CMS information. Right now we need to get information about all Design Studio Bookmarks. No problem in Excel, but how to use it in a WebI document?
Ok, I just checked the universe. Unfortunately that is not too much we can do (only si_infoobjects is used as far as I can see). So maybe we have to stay on the Excel tool for the moment.
It only works with 4.2 SP3 and future releases. But yes, it’s worth it. It doesn’t have all of the information I get from the SDK code I’ve written, but it provides a lot of good info and it gets better on a regular basis.
The BI on BI (“CMS Universe”) does not need auditing to be turned on to work.
It accesses the CMS subsystem (using APIs that translate contents of the CMS database repository (e.g. CMS_InfoObjects7) tables.
Some of the data is similar to the audit DB’s data, some of it, not so.
Basically, the CMS Universe will give what we call “shallow” metadata (folders, document names, owners, scheduled instance properties, create/update timestamps (updated as per CMS update NOT human-updated – although often the same ; no SQL/universe objects+filters+derived table SQL or other “deep” metadata as we call it – that’s still only accessible via some audit data but mostly through APIs)
If you are on 4.2 SP03 and want to use the new CMS universe, be aware that patch 5 “uninstalls” the driver (it won’t show up under SAP connections when you try to create a new connection). I’ve heard patch 6 corrects that.
Does anyone else have this universe working in 4.2 SP4? I imported the universe and configured the connection but I get the following error when trying to create a new query:
while trying to get the length of a null array loaded from a local variable at slot 53 (Error: INF )
Interestingly I can see valid data using Values from List when I drag a dimension into the Query Filters pane . I also imported the set of sample webi docs and they give the same error. Maybe I’m doing something wrong.
Our 4.2 SP04 instance is also missing the folder that contains the CMS driver. There should be a CMS folder under [install folder]\SAP BusinessObjects Enterprise XI 4.0\dataAccess\connectionServer.
