Universe - English to Italian
Is there away to convert Universes and Reports created in English to Italian?
b
bomainkee (BOB member since 2004-05-28)
Hai,
What’s the purpose for to change the language, anyway i think its not posible.
cheers…
thangavelu :india: (BOB member since 2004-12-14)
Hi bomainkey,
Actually there is a way to translate all object names and descriptions in a Universe from one language to another.
As the descriptions are stored in the metadata repository tables in an unencrypted format.
You should take a look at this thread: Managing multiple languages in BO
If you want to change the locale of a report, I guess you could also do this by directly modifying the Repository tables, but haven’t done it myself yet.
HTH
Snoopster (BOB member since 2004-10-20)
Modifying Repository tables is unsupported - you can also use vb to update the universe object names from an excel spreadsheet- trying searching on update universe description
hth
ottoman
Ottoman :uk: (BOB member since 2002-10-04)
