Universe Designer Problem
I last worked on my Universe on Thursday, and everything was functioning properly. I come in this morning and now, when I try to create/edit a Dimension/Measure/Detail/Condition, the window opens and then disappears. When I try to create/edit again, nothing happens. I have restarted Universe Designer and even restarted my laptop completely, but I still get the same problem. I’m basically stuck on my universe because I can’t edit or create anything.
Any suggestions?
travisbelt :us: (BOB member since 2010-06-14)
So I’ve uninstalled and reinstalled BO Edge 3.1, problem still persists. I’ve tried it on two other machines and there is no problem, so obviously it is my machine.
When I uninstall/reinstall Edge 3.1 and go into Universe Designer, the History still shows all of the universes that I last accessed. So, I’m assuming that it wasn’t a complete uninstall.
I went through and deleted all of the known folders after I uninstalled the software, but I didn’t go through the registry. Are there files hiding somewhere that I haven’t seen?
Are you using, or have you recently used dual monitors?
