Can any help me out in designing the universe using the excel sheet as the Datasource.
Crazy
crazy (BOB member since 2007-08-02)
Crazy
You cannot use the Excel file to Design your universe.
Siva.M
looksmee (BOB member since 2006-02-08)
I believe (s)he wants to use Excel as the data source for a universe, in which case it can be done.
dessa (BOB member since 2004-01-29)
Ensure that the following steps are done before inserting a table from Excel sheet into a universe.
haider (BOB member since 2005-07-18)
[Moderator Note: Moving from General Discussion forum to Semantic Layer.]
I am getting the error as Driver not capable:Transactional mode while doing the check integrity.Can you help me out.
Crazy
What integrity checking do you expect it to do from an Excel source? It’s not a database…
Anita Craig (BOB member since 2002-06-17)
Thanks for your information
Is there any other precautions that has to be taken while designing the universe using the excel sheet and also at report level.
Crazy
I’ve never done it, but if I were going to try, I’d do a search to find all posts in this Semantic Layer forum that have the keyword Excel and read through them.
Digpen has a nice tutotrial on his homepage detailing how you set up Excel as a data source.
yes… its mandatory settings… (like highlights the data and name box naming etc )
however my trouble in report scheduling …
if my excel will get replaced periodically through scheduling, then each time i need to perform these setting manually…
can we automate these setting …
if Yes, how… ? if anybody can provide the answer for HOW, that would be great help for me ?
thanks in Advance…
Vills (BOB member since 2007-10-24)
